ASP 7 BUG OR NOT Translate point switch layer
when i Translate point with switch layer it snap on i turn on interpolate sub-layer example... face front view to face side45 view interpolate smooth BUT face side45 view back to face front view it start to snap even when i render it or manuly move the slider back on forth... help anyone vern, sline...
ASP7 BUG see for yourself do this
1. layer 1 create a any shape
2. layer 2 copy shape from layer 1 to layer 2 and move some of the point with the transulate tool
3. create a switch layer and put layer 1 & 2 inside of it on turn on the interpulate sub... in the switch layer option
4. in frame 1 right click and select layer 1 to add a keyframe from the switch layer
5. in frame 10 right click and select layer 2 to add a keyframe from the switch layer
6. in frame 20 right click and select layer 1 to add a keyframe from the switch layer OR any frame you want to use 1 to 10000000000 etc
7. here the bug when you move the slider in the timeline manually from frame 1 to 20 and 20 to 1 back an fort instill of a smooth transulation between both shape it transulation then snap to the keyframe
my pc is 1gig memory 2mh processor
ASP7 BUG
ASP7 BUG
Smith Micro, PLEASE stop cross posting the same thing all over the place. Post it once in one place and then let it go. You have posted this bug and your dissatisfaction about it in 3 different unrelated topics.hothead wrote:ok boss my bad but it smith micro fault i well stop post comment sorry...
-adrian
hehehe, it's nice to have a little humor on all this tense ambient.madrobot wrote:Smith Micro, PLEASE stop cross posting the same thing all over the place. Post it once in one place and then let it go. You have posted this bug and your dissatisfaction about it in 3 different unrelated topics.hothead wrote:ok boss my bad but it smith micro fault i well stop post comment sorry...
