Paint bucket problem
Cowabanga
Post by Cowabanga »
Hey,
When I want to fill the drawing, it just don't let me, yes the shape is closed.
Image:
sbtamu
Post by sbtamu »
Try to create shape again and zoom in till it turns checkered. That works for me sometimes.
Sorry for bad animation
Mikdog
Post by Mikdog »
Try deselect the points where the arm goes into the body so you're left with only the points surrounding the shape. That should work.
Also make sure all the points are actually making a closed shape. Go to your points tool, 'T' I think, then check the box at the top that says 'Automatically Bind' or something, then click a point where an intersection occurs. This should bind and loose points together.
Anyway, if you want to animate that character, that kind of shape won't work for you.
Cowabanga
Post by Cowabanga »
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
@sptamu and Mikdog: Didn't worked.
@selgin: I know it won't work for animation, I just want it for a design on DeviantArt. :)
crsP
Post by crsP »
This is what Mikdog means, and it will work. Forget about the Automatically Bind part for now.
Cowabanga
Post by Cowabanga »
Yeah, it's working now. Thanks! :)
