Turn off points while drawing?
gdub
Post by gdub »
Hi,
When drawing with the freehand tool, I find that the points being displayed can be distracting, and it's hard to see the lines that I'm drawing. Is there a way to turn off the points while drawing?
Thanks!
Mikdog
Post by Mikdog »
At the bottom right of the screen there's a button called DISPLAY QUALITY. Click it then uncheck paths
gdub
Post by gdub »
Thanks for the info, that must be a feature in the pro version, I should have mentioned that I'm using Debut.
JCook
Post by JCook »
The only trouble with that is that you can't see the line you're drawing either, until you finish drawing it.
Jack
Anyway, you can create a vector layer and leave it empty. Then, when you don't want to see any of the construction curves, just select that empty layer.
I used to do this on version 5 (it was faster than opening the display quality menu).
gdub
Post by gdub »
Thanks for the list of techniques, can't wait to start trying them.
