Why Switch Turn is so smooth?
- patricia3d
I have got switch_turn.anme file from the forum, I have forgot the forum link. While studying this file, I created one Square and
one Round with 4 Points 2 Vector Layers and put them in a Switch.
http://cid-ce583d1094a511ea.skydrive.li ... chturn.zip
Please unzip and you will get switch_turn.anme
Original File has switch layer Turn Control
and I have created switch layer myTurn
I don't know why original Switch layer turns head smoooooooooothly and why mine is
not turning smoothly?
LeeHasPencil
- patricia3d
LeeHasPencil
Interpolation on switch layers only works when each layer has the same amount of points.
Switch layers seems to not interpolate curvature.kkrawal wrote:Thanks for answer so fast.
In the uploaded file
'Interpolate Sub-Layers'. is not checked.
But I checked this in the file I hve just now but even that my switch layer its not turning somoothly?
viewtopic.php?t=6043&highlight=curvatur ... nterpolate
- patricia3d
No, simply you have broken the current inserted keyframes. They are based on layer names. If you change the layer name the keyframes that references the old layer name are not changed.kkrawal wrote:I tried different ways, but its not doing. While study this, I found one more secret in this file that Just change the Name of Head Layer and the smooth turn will finish?
- patricia3d
