Moderators: Víctor Paredes , Belgarath , slowtiger
Okse
Posts: 37 Joined: Sat Jan 09, 2010 5:56 pm
Post
by Okse » Thu Jan 14, 2010 8:52 am
....to a bone, I know it can be done I've seen it. But every time I have a go it messes up.
If anyone could help me I'd really appreciate it.
My names Okse by the way and ths is my first ever post, so "hello" and all that
patricia3d
Posts: 726 Joined: Wed May 30, 2007 8:38 pm
Post
by patricia3d » Thu Jan 14, 2010 8:55 am
Open the startup file
In Layer Window
Goto Frame 1 and ( Select Mouth with RMB ) , you will get submenu to select,
Goto Frame 10 and Select Mouth with RMB ) you will get submenu to select 2nd Mouth
Goto Frame 20 ..
Okse
Post
by Okse » Thu Jan 14, 2010 9:00 am
thank you, I know how to assign keyframes by switching, but I need to no how to assign a switch layer/object to a bone.
b15fliptop
Posts: 167 Joined: Thu Mar 10, 2005 9:11 am
Post
by b15fliptop » Thu Jan 14, 2010 9:57 am
You've got it the other way around. Switch layers are also bone layers, so you create the bone on the switch layer.
Stan
Posts: 254 Joined: Sun Apr 19, 2009 7:22 am
Post
by Stan » Thu Jan 14, 2010 4:29 pm
To assign a layer to the bone:
1. Make sure frame zero is active
2. Activate the Bind Layer tool
3. Activate a layer inside the bone layer
4. Click on the bone that you want your layer to be assigned to
