arm bending
meltedtoons
arm bending
Post by meltedtoons »
I use adobe flash, and it's easy to do bending arms there so I did the similar thing with bones.
Take a look.....
Examples...
1. http://meltedtoons.com/armbend.swf
2. http://meltedtoons.com/arm.swf
3. http://meltedtoons.com/armbend2.swf
Tell me what you think..
LeeHasPencil
Post by LeeHasPencil »
Nice bend ^_^
Are you using to vector layers for that, upper and lower arm? Or is it two shapes?
I haven't figured this one out yet, I still have jelly arms myself lol.
The best and simplest arm rigging I have seen so far is on this thread, there you will find this file.
Since I downloaded it I always use his technique.
Obviously the credits are for mandcon.
meltedtoons
LeeHasPencil wrote:Nice bend ^_^
I use two vector layers. I add two bones and to animate I use the translate bone tool and Manipulate bone tool.
heres the file for the first one:
http://meltedtoons.com/armbend.anme
you have to copy and paste it to notepad and save it and open it on Anime Studio 6 Pro. If you have a version below Anime Studio 6 Pro let me know and I'll make you another Anime Studio 5.6 Debut file
LeeHasPencil
Cheers, both. :)
meltedtoons
if anyone has questions you can email me at eric@meltedtoons.com
neeters_guy
Post by neeters_guy »
selgin wrote:The best and simplest arm rigging I have seen so far is on this thread, there you will find this file.
Thanks, Selgin. I read that thread before, but missed that link. You're right, it's amazingly simple, yet effective.
Meltedtoons, in a setup like yours, you could eliminate the extra bone translation keys in your file by making the overlapping area a perfect circle and point the bones dead center. Otherwise, when you rotate the lower arm, the elbow goes out of alignment and you have to tweak the arm.
meltedtoons
Well the reason why I'm doing this is cause I like animating like on flash and using the advantages of Anime Studio's tools such as the bone tool.
meltedtoons wrote:Well the reason why I'm doing this is cause I like animating like on flash and using the advantages of Anime Studio's tools such as the bone tool.
What do you mean you like animating like on flash?
At least for me it's more important the result than the way you made it. I think the flexibility of the mandcon's arm is very superior than working with separate parts for arm and forearm. And it's very simple to configure that arm technique, so you win flexibility without losing time, which is fantastic.
For me it's about how do you solve the problems presented and how do you adapt the tool to your desired product (and not viceversa).
meltedtoons
well part of the reason is, I used anime studio since, 2006 and I hated how long it takes to set up the bones. so, thats why i switched over to Flash but I didn't like Flash because it required Scripts ALOT... even for a type of lip sync.
Also I like it when it gives me alot of control of the movements. And I donno why but I like using the long way of techniques. It's more satsifing then just moving a bone and saying voila! this is only refereeing to some parts of animation, like head turns, I wish i can do that in a click of a button. And I'm sure that'll happen some day....
Wow, that really is a confusing reply.
"I like using the long way of techniques..." and "...I wish i can do (head turns) in a click of a button..." !
Which is it?
LeeHasPencil
Do you want the long or short answer? ;)
If you want head turns at the click of a button, use a 3D application.
uddhava
Post by uddhava »
selgin
Since I downloaded it I always use his technique..
Somehow the link to file for me is not good. I don't find a file only a page with a bunch of words and numbers like programers language or something. Any help?
udd
Try with right click, save file as. The codes you are seeing is your explorer opening the anme file, just like when you open it on notepad.
