...make a person look in different directions?
salp42
Post by salp42 »
Like in the Simpsons when someone is talking to a group of people they turn there head a lot. Is there and easy way to do this? or do you have to rearrange the points every time you want to turn someone's head? Is there a certain bone set up? (my set up just makes the head move so that the ear goes to the shoulder)
I was thinking about making the eyes move but i don't really want to do that until i know how to make the head turn.
Search the forum -- a number of people have solutions to this.
tonyg
Post by tonyg »
Depending on the style you can try a switch layer with the head drawn at different angles.... unless I have misunderstood.
arfa
Post by arfa »
I wonder if someone had the time to collect a few of the better postings on turns?
It comes up so regularly it would almost warrant a sticky.
Short answer... No.
If you have a regularly used rig then it is worth developing switch layers or front, 3/4 etc. views but as often as not there are so many variables as regards context that I find a combination of plain old point manipulation and quick shift, blur-to-new-view the easiest. Ie., treating each situation anew.
The idea of a 'silver bullet' turn solution has long ago dropped off my work sheet - but not my wish list :lol:
Imago
Post by Imago »
I've drawn one head position for every direction and use the switch layer to use them, but this method is good for low frame rate movies.
I think the best way to create fluid head turns is blend morph (which are based on actions).
I have posted about here
viewtopic.php?p=77099
But it's just my opinion
Have you seen this?
viewtopic.php?t=7244
arfa
Post by arfa »
Thanks for reminding me Genete. Yes I have looked through those links.
It is interesting to see that everyone has a different approach. This reflects the flexibility of the software and mixed styles. Selgin is right about fluid turns (morphing) but it is totally fussy about point count. I work more like Imago with different views in layers - not always switches. I am still quite rough so prefer being able tweak the points and generally mess around.
I have been recently studying the old Disney classics - Snow White, Fantasia, Pinocchio & Alice in Wonderland. Inspiring.
Bless tweening i reckon :D
uddhava
Post by uddhava »
selgin wrote:I think the best way to create fluid head turns is blend morph (which are based on actions).
Wow, thanks for this information selgin! By the way, is there a way to create a full side view with this technique?
udd
