I need to make a small digital thermometer in an animation, so that the numbers in the readout will change quickly as something else is animated. It needs to go from 0 to 30, and then back down to 17, but also be controllable as to how fast the numbers change. My first thought about it was to make all the numbers from 0 to 30 as switch layers, and then animate them every couple of frames, so that, for example, on frame 1 the number would be 0, then at frame 3 the number would be 1, and so on. I'm wondering if anyone knows of an easier or quicker way to do it?
thanks,
Jack
Digital clock with changing numbers
I think, but I'm not sure, that there is a script which automatically generate keys for a switch layer.
I'm not sure, but maybe it was made by Rylander.
PD:
Here you have
http://rylanderanimation.se/tag/anime-studio+scripts/
There is a script named loop switch, that should work.
PD:
This worked like a charm, using Rylander's Loop Switches script (thanks for that link, Selgin). I used a digital font in Illustrator, making the text 88°C and converting it to outlines. Then I imported it into ASPro and made copies of the layer, naming them for the numbers, and deleted the parts I didn't need (thanks for that suggestion, slowtiger). The only tricky part was figuring out the range and the interval for the switches so that it ended on the right numbers, but even that wasn't hard. So, I had a line on a graph representing temperature, and as it grew the numbers went from 0 to 30, held there, and then as the line came down again the numbers went in reverse from 30 to 17. Perfect.
I haven't tried the Papagayo method yet, but I'll look into it.
Thanks so much for your help, guys.
Jack
Jack
