Animating Images
bRiMaTiOn
Animating Images
Post by bRiMaTiOn »
I know Anime Studio can animate images real well. It can do frame-by-frame pretty decent too. I just needed a reminder on how to do this. Was there a way so I could stick 48 images/frames into one switch folder(at once), and then have them automatically switch through one frame at a time?
I know the long way where I would import each image one at a time and then I would hit the switch button on each frame for each corresponding image.
The long way seems inefficient. Can anybody help me out? Thank you.
On the top menu, go to scripts>Image>Import image sequence
double click on the first image of your sequence. then all will be imported to a switch layer and showed one by one on time.
all your images must be on the same folder and be named on a logic number sequence.
bRiMaTiOn
Post by bRiMaTiOn »
No way! Thread over. Thank you. Also thanks to mkelly for the advice.
