Bone audio Wiggle Script Query
Shanty Baba
Post by Shanty Baba »
I want to move a character along the X-axis, backwards and forwards, in synch with the volume of an audio file. The Bone audio wiggle script seems the nearest automatic way to achieve this.
But of course this just controls the rotation of the bone. This there a way I can manipulate this rotation into a translation (x-axis) movement, maybe using other bones, or maybe a script?
Cheers,
Shanty
You can do it using controlled bones, a very clever guy here played with some numbers and get it (thanks, Genete). You'll need at least 3 bones
Look at the file
http://www.mediafire.com/?tyvnmj4w40d
Bones must have the same lenght, use the grid to make it.
First, draw a chain three horizontal bones as you see on the file Then, select the second and in bone constraints, go to angle control bone, chose the name of the first bone (if it haven't name, you must named it selecting it with select bone tool and writing on the text rectangle wich will appear on tool propieties) add -2 on angle control bone.
Select the third bone and do the same, but add 1 instead -2.
Now, when you rotate the first bones, the third bone will move only X.
PD: the file has another bone, it's just a bone which controls the first one. On your own construction you can have or haven't it.
Shanty Baba
Thanks very much for that Selgin. Just what I wanted. I had a problem downloading the file, but your clear description enabled me to construct it myself.
Cheers,
Shanty
Shanty Baba wrote:Thanks very much for that Selgin. Just what I wanted. I had a problem downloading the file, but your clear description enabled me to construct it myself.
Cool, it was so hard to explain it! :oops:
