rotate points axis
craigb
rotate points axis
Post by craigb »
I see now that when you select the rotate tool a centre of rotation for the selected points is shown but you can`t seem to move it.
Being able to select points and move where the centre of rotation is would
be very useful.
AcouSvnt
Post by AcouSvnt »
If you then use the translate tool on those same selected points, it achieves the exact same result as if you had rotated them around a different axis.
-Keith
craigb
Post by craigb »
Yes thats true but not very intuitive,I find it much easier to move a pivot as you would in illustrator and then see the result as you rotate rather than rotating points around a averaged centre and then having to re-aline them.
just a thought.
