using Transparent GIF files
Is it possible for an image layer to take advantage of a transparent GIF's background? I am importing one but AS is giving it a white background. I am trying some cut-out type animation, and the pieces need to each have a clean border with no square background like in a picture.
I don't know exactly how it is in photoshop, I use another photo editor. But there should be like this, alpha will be showed as a chess table, if not, create a new layer from your image and erase the background color using the eraser or similar, in the places erased there you'll see the chess table look. then save or export your archive as png.
I work in corel photopaint, in that case I must to create a new object from the image, then erase the background with the eraser and create a mask from the object. Then export as png and in the export dialog chose create the from the mask.
The advantage of png over gif is that gif provides a binary mode of transparency, I mean, a pixel can be absolutely transparent or absolutely opaque. Alpha, instead, can give a pixel a percentage of transparency, so you can have a pixel 50%, 20%, 70%, 10% or 100% transparent, giving you the possibility to have much softer images.
