Free transform tool
foundmarble
Free transform tool
Post by foundmarble »
In PS (I believe, Flash also), you can scale, rotate or translate a selection with 1 tool.
Is this possible in AS? If so, I am wondering the cons against this.
One con I can see is the animation side of it. Having separate tools would separate the key frames which would be needed.
I was thinking the combined tool should ONLY be for used in the initial drawing on frame 0. The other 3 tools would then be used for animating, thus separating the key frames to scale, translate, rotate.
Peace,
Found M
Are you talking about bones and layers? Points don't have separate key frames for scale, rotate etc. All points have are translation.
I could see a combined point tool as being useful. Not so much for layers and bones. Not sure why. I guess I am so use to keeping those things separate in my head I like having different tools for translation and rotation.
A combined POINT tool would be able to work on any frame without causing trouble.
take a look to universal point tool
viewtopic.php?t=3298
I haven't used it seriously, but seems to be it's pretty good.
foundmarble
Put animating aside for a second.....(funny, since this is an animation program, but go with me on this wierd journey)
If I could manipulate just the points (no layer or bone manipulation) in order to get the desired shape(s) with one tool on frame 0 this would save a lot of my time on creation. If you need a reference, open Photoshop and use the free transform tool.
Now put animation back on the table...
I would then use the existing tools (separate- but equal :roll: ) to manipulate the points. Come to think of it, I could use this "universal tool" since points do not have separate keyframes for scale, translate and rotate.
Once you use a tool like the free transform tool (in PS) you will see the benefit (without having to drink the koolaid) :P . Truly a time saver.
Selgin, I'll look at the thread.
Thanks guys for the quick response. I'll tell the boss you need a raise. :lol:
Peace,
Found M.
foundmarble
Here is an image to explain.
Hopefully, I am not insulting your intelligence. I am doing this to put an image to my verbal description.
When you touch the handles on bounding box you would receive the scale tool (#1)
When you are in the vicinity of the corners, you would receive the rotate (#2)
When you are inside the box, you translate the selected object (#3)
Heck...you could even put a shear attribute with the tool also.
Again this is all about points, not bones or layers. However, I can see a use for a universal tool for layers also. But, that could be a discussion for another day
Peace,
Found M.
foundmarble
Wow, Sometimes I really am an idiot. :shock:
Sorry, I didn't even realize you can hold down alt to rotate points while using the scale tool and the opposite is true while using the rotate tool.
Disregard this post.....sorry.
Damn, and I went to the trouble of making that image. curses! curses!
*hands over head while camera pans out* :x
Peace,
Found M.
Don't kick yourself too much. I didn't know it either!!
:oops:
TheChewanater
Post by TheChewanater »
I still think it's a good idea.
Dodgy
Post by Dodgy »
I think so too. I might have a go with my limited scripting skills...
kphgraphics
Post by kphgraphics »
foundmarble wrote:Wow, Sometimes I really am an idiot. :shock:
Peace,
Found M.
Wow, is right i did not know this either.
