P.S., Can someone help me to post pics?
Hybrid What?
Hybrid What?
I am confused, it says Anime Studio Pro 5 Hybrid Retail. I am scared to open the CD for I may not be able to return it.
It is for Windows and Mac, but it says hybrid right above the serial #. I want to make sure it is not an education copy. When I bought it, there was nothing confirming that it was academic. Here is the page I bought it from: http://www.buy.com/prod/anime-studio-5- ... 60061.html
Also this was the license agreement page: http://my.smithmicro.com/eula.pdf
Finally How do I register this again to smith micro?
Do I need to re register my email?
I don't think you need to worry. $176 looks like a pretty normal price (depending on where you buy from). Education copies are a lot cheaper than that. The price at the Academic Superstore is $90 for Anime Studio 5 Pro.wlan wrote:It is for Windows and Mac, but it says hybrid right above the serial #. I want to make sure it is not an education copy. When I bought it, there was nothing confirming that it was academic. Here is the page I bought it from: http://www.buy.com/prod/anime-studio-5- ... 60061.html
There's a Register option under the Help menu when you install the program.
T tomak, I got mine for $71 which is now concerning me. It is still unopened and I carefully read the fine print on Buy.com and nothing about educational version. But it came in the box a little crushed. I think that was the sale reason.
P.S., the price changed over the weekend.
I don't know if I got lucky or if I got ripped of. I read the box, nothing about an educational version.If I can learn how to post pics on here it would be easier to show you what I mean.
Dude, AS doesn't come in an educational version. There's Anime Studio 5, and Anime Studio 5 Pro. It sounds to me like hybrid means a mac and win version in the box. Possibly both versions use the same serial you got.
Sounds like you got it cheap because the box is damaged.
I'd suggest emailing smith micro if you still have concerns. They have a tech support email thing which I found to have a fast turnaround with support.
Yeah, the discount's probably because of the damaged box, though Buy.com has a market place where individuals could resell copies they've previously bought - maybe you bought one of those? But if you want to be sure, you should contact Smith Micro directly to see what they have to say about it.
You should definitely contact Smith Micro to see if you can get a free upgrade to AS6.
Hi Wlan,
You'll have no opportunity to upgrade for free if you didn't buy Anime Studio directly from Smith Micro.
Regarding using the software, you should have no worries as long as the envelope that contains the installation CD is still sealed. If was already open when you received the software then you've purchased a resold copy.
If I'm not mistaken, Anime Studio will only import .obj 3D meshes. Blender can certainly export .obj files so the two should make beautiful music together!
Regarding using Anime Studio like Flash, then I think you might be in for a disappointment. While Anime Studio can export .swf files, it really isn't designed to build websites like you can with Flash. Of course if you just want to export a .swf file from Anime Studio into a website, then you should be fine as long as you know that there are certain effects that Anime Studio can handle that will survive the translation to Flash's .swf format.
I hope that helps!
Pierre
I hope that helps!
Pierre
I'm pretty sure Mike said if you bought it recently, you can upgrade for free (no mention of whether you bought it directly from Smith Micro or not). That being said, if you did buy it from the marketplace instead of direct from Buy.com, then it might not count cause it's resold. Either way, just ask them - it can't hurt. Even if they say no, all you wasted was a few minutes to write to them. Plus, you'd kick yourself if you don't ask and then later find out you could've gotten a free upgrade after all, only they're no longer offering it anymore by then.
