You're a legend Wes.
Always chipping in to help.
Good on you mate.
Trouble in Wide shots
- Rancid_Snowman
No, not the layers. I only really checked out the "rest" layer. If you keep selecting the shape with the select shape tool and deleting, you'll find that there are five or more shapes on that mouth curve. Well you select and it shows the checkerboard pattern you'll be down to the last one or two shapes.
The reason this stack of shapes causes the mouth to appear to open as you zoom out is because there is a slight anti-alias bug. Each shape sharing the same edge and being adjacent in the shape stack order pushes out slightly around the one above it. More shapes just make this a cumulative effect, each one poking out just a hair more around the one above it.
It may be easier to delete all of the shapes and just make sure you only create one shape (or as few as possible).
- Rancid_Snowman
