Modifying the image sequence to import as layers?
I find myself wasting time loading one image at a time. Is their a way to make is so the script just loads every picture in folder as one picture into a new layer with the layers name as the file name?
Dale
There's both janimatic's import directory script. (scroll down to post #13) and my batch image nautilus script. They should both do exactly what you want depending on which system you use.
All the janimatic links are broken, which is a shame, as the js_image_sequence.lua I've got seems to have a problem (which it didn't use to have...). So this *is* a genuine question.
Edit: aah -- just tried something out. The images I was trying to import had five digits at the end. I changed a group of them to four final digits and they imported OK. Something to bear in mind if you don't know (or maybe it's me just being a dork again!?)
