Chewy, the older rig did need to be layer flipped at certain points to complete a full rotation, but the latest one can do a full 360. Well, at the very least it does the same as the old one. It just depends on how exact I want the 3D effect to be.
New hand rig results
Don't worry Vilma, as soon as I get this all worked out, I plan on making a tutorial of the technique.
synthsin,
Wow you made a lot of advancements. I did finally figure how the hand worked to a point. I am using it in the builds I been working on. The 3D look is so nice to have, makes it look more like hand drawn then flash.
Keep up the good work and can't wait to see how you worked out the extra detail.
This has got to be the most impressive work I have seen with ASP - had I not known it I wouldn't have thought it possible - synth, you've moved the goal posts.
This solves one of the hardest problems in 2D vectoring, how to create the fore arm joint crease. Genius stuff.
All I have to figure out now is how to build one! There goes the free time I didn't have.
Look forward to the final tutorial.
Rhoel
Rhoel
That arm is absolutely stunning synthsin75!
Great work!!!!
D.K
Great work!!!!
D.K
My store on Renderosity:
- TheChewanater
PocketGoat
dead thread?
Is this a dead creation? or was it just a joke after all?
Acochran_89
Acochran_89
