Hi,
I'm a noob who will likely be using Anime studio 5 to create cut-out style animations (similar to odinsphere for the ps2)
I've figured out the basics of importing images, assigning bones, and getting things to move or rotate as needed. I can create keyframes as needed.
My problem is that I sometimes need to copy ALL the data from one key frame to the next for ALL bones and layers (and there are many)
I've NOT yet found a way to do this without selecting each darned bone or layer and selecting and copying all of the frame data (one at a time).
Please tell me there's a simple menu selection or keypress that can do this? (i'm working on a PC)
thanks,
A noob needs help copying ALL frame data to another frame
Holymonkey
If you have all your bones on the same bone layer for a character, then that is basic stuff.
There are 2 rows of keyframes fo your animation, the top row is all keyframes and the bottom red row is the selected item's keyframes.
So select the top dark row and you are done.
You can also drag your marque over all keyframes of the entire document, wherever your timeline is when you paste is where they all get pasted to.
Make sure you use the copy past function only from the timeline itself.
Holymonkey
Holymonkey
