Well I exported my animation to a SWF, and I view it and nothing happens.
I am wondering why? If someone could please help me diagnose this problem, I would be much appreciated!
Help with anime studio
Is it the blank gray color of the AS default background? If so, are you sure you have created swf compatible content? If in doubt, check out the flash tips in the user's manual.
http://www.lostmarble.com/moho/manual/flashtips.html
With so few information, we have to guess:
- Did you create any animation, which means anything after frame 1 in the timeline?
- Did you create anything visible within the project area (the blue rectangle)?
- Did you set the layers to "visible" before exporting? (If you set a layer to invisible there, it will not be exported - very handy for compositing.)
- Did you export anything after frame 1 in the timeline? (Type in some numbers in the export panel.)
- Did you check "extra SWF frame" in the project settings?
