Layer visible in other layers?
Kaven
Post by Kaven »
I need all of my layers to be visible whenever I pick any layer. Example, I have layers A B, and C.
Right now, whenever I pick A, B, or C, the other layers disappear. I want to be able to see all the layers at the same time, no matter what layer I pick. How do I do this?
Be sure that the layers aren't inside a switch layer because it seems to be the reason for single visibility.
Kaven
Post by Kaven »
They arn't in a switch layer. Last night, I tried making groups, and it worked. But today, when I make a new group and add more than one layer, it's only showing the selected layer. This is getting very frustrating. Any suggestions?
mkelley
Post by mkelley »
You *did* create all your layers on frame 0, didn't you?
If not, it might be as simple as the visibility switch being turned off (the default up to where a layer is created). You do, of course, see any layer selected regardless of whether the visibility is on or off.
Otherwise -- post the file and I suspect the experts will have it working for you in minutes.
In groups, if only one layer has the eyeball visibility icon checked, selecting another of that group's layers will toggle the visibility to the selected layer. Also, if you don't have any shapes made of the curves, you'll need to enable construction curves in the layer display settings at the bottom of the workspace.
Those are my best guesses. :wink:
There is definately some missing element in your description. Some form of "user error". Don't take that the wrong way. 99% of problems are user error even for the best of us. ;)
The best way to work this out would be to see a screen capture or file or both. A screen grab of the AS interface so we see what you see.
