Could not open file. Error details: Read error at line 92130
danielandrus
HELP!
i was working on a file. after saving and closing the file i tried opening it up again and got this message:
Error details:
Read error at line 92130. In code file C:\Documents and Settings\Mike Clifton\My Documents\Develop\lm_tree\lib_moho\m_mesh.cpp, line 143.
does anyone know what happened? i've been working on this for a while and it would set me back a LOT if i lose the file.
any help is very appreciated.
Thank you
Error details:
Thank you
Can you post the damaged file somewhere?
I could take a look at the source and see if I can fix it for you. The files are plain text and often you can fix "simple" problems.
In the future I strongly recommend that you save incremental versions of your projects just to protect yourself from things like this. Nearly every application file can get corrupted by all kinds of things, system hiccups, crashes... whatever.
danielandrus
For those interested I was able to fix the file. I had to delete a layer at the end that was missing a big part. I think the file got "squashed" during a save and a big chunk was left out at the end.
The number 92130 was actually the line number in the text of the file! Big file.
So, just an FYI for others. If the file won't open... you should panic of course... but don't give up hope.
danielandrus
Sorry I couldn't help you out Tashi. Good luck with redoing the work.
I plan to include a tutorial for editing the file format on my new site. It won't have "complete" documentation on the file format but it will give you enough info to get around in it.
I suggest anyone wanting to do that kind of thing should get a good text editor like the free open source program jEdit.
Tashi,
I just sent you the "fixed" file. I went back and looked through it in AS. It looks like a ton of the actual animation is still there. All the layer animation anyway. It only "seemed" to have lost layers in that one switch layer I mentioned but you will have to say for sure.
AS is so weird. The layer order in the file is not the same as the text file format. In the file format layer order is determined by when it was created. If you start moving layers around in the layer palette the layer stays right where it is in the text file. This can throw you off a bit if you think you are looking for the last layer or the third layer.
Make sure you put the new file in the same place as the old one or the image layer links won't work. I gave it a new name.
Coolburger
Coolburger
Heyvern,
I read these posts that you were able to help out these guys with a read error problem and would like to know if you could try fixing a file for me?
Error details:
Read error at line 56288. In code file C:\Documents and Settings\Mike Clifton\My Documents\Develop\lm_tree\lib_moho\m_mesh.cpp, line 51.
Please help
Thank you
Error details:
Please help
Thank you
corrupted file
hi everybody, I'm new here
I have the same problem...
could you teach me how to fix it?
o can somebody fix it for me?
I'ts really urgent, please
The SciTE.exe text editor is also brilliant for programming and text file editing. In Lua mode fir instance, it colour codes the key instructions, making readability a cinch.heyvern wrote:... I suggest anyone wanting to do that kind of thing should get a good text editor like the free open source program jEdit.
It has switchable line numbering, end of line visualizations and a host of other features.
And its free.
R
