i am wondering if i design a character in
AS can i export JUST the character to a PNG
with alpha?
i have tried saving in different
formats, but I always get the background
along with the character, so there is really
no way to manipulate just the character
in another program.
[/img]http://www.mediafire.com/?sharekey=7225 ... b9a8902bda[/url]
exporting with alpha
- toonertime
- Lost Marble
I assume you're using the File->Render menu command. With that command, there is no alpha channel. However, if you use File->Export Animation, the alpha channel does get generated. When you use "Export Animation", you can set the frame range to just a single frame if all you really want is one still image.
So what you probably want to do is use Export Animation with PNG as the export format, and set the start and end frames to be the same number.
- toonertime
png export
no, i was not referring to just a render.
i mean a full animation of just a character.
how is just an animated character without
a background exported into a movie that
another video program can composite?
- toonertime
thanks
thanks for the response! my stupid new
pinnacle video editor actually won't
accept a QT millions of colors option,
the bastards!
I have an older Magix video editor
that I will give it a try in.
Thanks again, Mr. Synth!
the bastards!
