----------------Tools-----------------
syn_x_app-------------------------------------------------
viewtopic.php?p=67666#67666
Open external applications from within AS.
syn_select_layer!!!----------------------------------------
This new tool allows you to select vector layers in the current group by clicking on a shape or vector edge on that layer.
For example, say you have this sort of layer setup:
Group (or Bone) Layer
-Vector Layer 1
-Vector Layer 2
-Vector Layer 3
If you have one of these vector layers currently selected in the layers window, you can move to either of the other two vector layers by clicking on a shape or edge on one of those layers. Say I'm on 'Vector Layer 1'. If I want to move to 'Vector Layer 3' I just need to click on a visible shape on that layer. If that layer's shapes are covered (hidden) by the higher layers' shapes, then I just need to estimate where an edge is and click there.
Up/Down arrows will move the currently selected layer up/down in the layer order, but this is not animated layer ordering. This feature is mainly used with syn_select_shape (below) to handle layers much as you would shapes. You can reorder them, but like shape order, these changes are global (document-wide). I would suggest only using this feature on frame zero, as any later animated layer ordering will make this feature behave oddly.
Ctrl + Up/Down arrows will select the next layer up/down, also just like handling shapes.
All of the following tools include the 'select layer by shape/edge' feature. Only syn_select_shape includes the arrow controls.
syn_select_shape--------------------------------------
This tool includes the syn_select_layer features. If a shape is selected, it works like normal ( the arrows change the shape order, ctrl+arrows changes shape stack selection, and clicking an empty part of the workspace deselects the shape). If you click on a shape of another layer (in the same group) it will select that layer. A hidden shape's layer can be selected by clicking on that shape's edge.
If no shape is selected, The arrow features work on the layers much as they do shapes.
syn_create_shape--------------------------------------
Edit:There are some problems with this create shape tool that I just noticed. I'd suggest using my other one without the shape order display or layer selection until I find time to fix it. Link to the previous version is below.
This tool includes my earlier creation method feature. In case you missed it, this allows you to select if you want to create shapes with 'fills only', 'outlines only', or 'both' before creating the shapes.
I've also included a new shape order display. A newly created shape, while still selected, could already have its shape order changed with the arrows. Now you can see where it is in the order without having to change tools.
This tool also includes the syn_select_layer selection feature.
(This is the version I'm currently using. It has the flood selection feature disabled as it often caused AS to freeze up. If anyone wants it back, let me know.)
syn_select_points----------------------------------------
Point selection tool with the syn_select_layer selection feature.
syn_translate_points-------------------------------------
Points translation tool with the syn_select_layer selection feature.
Download them here.
Download previous create shape tool here.
Just drop all of the 'syn' files into your 'tool' folder, and the 'fa' file into your 'utility' folder. All of these require Fazek's utility, so if you love Fazek's tools you'll love these.
-Wes
