lil trouble w sound while exporting
Hello there,
I wonder if someone can tell em what i am doing wrong with the animation which i just exported,
I used papagayo to synch a soundfile (.wav) correctly and used anime studio 5 to summon up a mouth, imported the switch thingy i made up with PGY and made a 1st run animation, of about 72 frames.
when i click on play, it works just fine, animation, mouth + synch and sound.
but the moment i exported it both to flash and avi, both files show the animation but the soundfile starts up, only hear the first tone and then the sound goes completely blank.
i used a .jpg file, a mouth and .wav file under soundtrack, and didnt compress the animationfile.
Did i do something wrong with the export ?
Hope someone can help me out,
regards,
indi
regards,
indi
Well, i tried the mp3 format, but sadly the mp3 format isnt showing in the soundttrack files.
and on another animation there is the same "choking" issue again.
movie format is now 596 kb
slightly less than the other one.
So i really dont understand the problem with the audio.
Am i really the only one having this ?
Indi
Indi
What do you mean 'isn't showing the soundtrack files'? Do you mean it isn't showing the wave form in the timeline? If so, you need to use the .wav soundtrack within AS. This is how it finds the mp3. Also I think the mp3 must have the same name as the .wav.Well, i tried the mp3 format, but sadly the mp3 format isnt showing in the soundttrack files.
If you continue to have trouble, I'd suggest posting a link to the AS and soundtrack files. That way someone else can try it out and see what the problem is.
