What computer spec do you use?????
At the moment im very limited to what I can produce{animation wise}When ever I create an animation my system crashes especially on anime pro studio.As you can see this is very annoying problem.I would be very grateful to fellow enthuisaists and animators alike if you could tell me what computer spec I need to make more complex animations(2d).As I need to buy another computer many thanks.
If you are creating vector art just about any computer capable of running XP will do -- I run AS on a very old (pre 2000) laptop and it works just fine. It doesn't even need a lot of memory (my laptop only has 256K -- not even a GB).
Using bitmap art will greatly increase your computer's needs, in both speed and memory and disk capacity. In that case I wouldn't get anything less than 4GB of core RAM and at least a 2GHz processor.
