repeating move how?
repeating move how?
why i dont want to animate a walking man again and again how can i make it to repeat 1 part of moving?
- Squeakydave
It's a pity we dont actually save a certain animation cycle to something we can use over and over like movie clips...
oh well...
oh well...
Fear Me Mortals
Hrm, Simpy, I believe that is available, if you group everything in your cycle under a top-level layer and save the file.Simpy wrote:It's a pity we dont actually save a certain animation cycle to something we can use over and over like movie clips...
Moho 4, under File; Insert Object ...
Moho 5, under File; Import; Moho Object ...
E.g. A cycling animation can be saved in one Moho file - and then imported into multiple other files and projects.
The new v5 Actions timelines are a different approach, but should be very useful - you could potentially use them to mix action snippets - a run action repeated 3 times, a jump action, another run action, a "stop and look at scenery" action, another run action.
I haven't tried importing anything with Actions yet - hrm, something to try this weekend, perhaps.
Regards, Myles
- spasmodic_cheese
Whaa?? Whats all this kafuffle???myles wrote:The new v5 Actions timelines are a different approach, but should be very useful - you could potentially use them to mix action snippets - a run action repeated 3 times, a jump action, another run action, a "stop and look at scenery" action, another run action.
Translation:
What are actions, how do i use them?
- Lost Marble
Yeah, it's not so obvious yet without a new manual. Select Actions from the Window menu. You can create new actions there - each action basically has its own timeline where you can create a short animation clip. Then, you can insert actions into the main timeline.
Tip: double-click an action in the Actions window to edit it.
This is a seriously cool feature.Lost Marble wrote:each action basically has its own timeline where you can create a short animation clip. Then, you can insert actions into the main timeline.
The equivalent of poses and ... umm ... actions ... in 3D software.
You can also overlap actions - the often-quoted example of having one action of the legs walking, and another action of the arm waving, then overlapping them so your character waves their arm while walking.
Regards, Myles.
- spasmodic_cheese
Woh nelly that is SOO NIFTY!!
I just tried it, as well as merging actions that is REALLY cool!
I remember i used a program called quest3d that had a feature like this, and it had a slider in it that let you sorta 'mix' the actions together.
e.g if i had a walk cycle and a run cycle, i could start with the slider right on one side then as the run cycle startedi could animate the slider to go across and smoothly go into the run cycle
how do i do that in moho? (create a jogging action between both movements??)
- Squeakydave
Meester Cheese! I've tried to play with it, but I'm coming up blank. If you've got it, please give us a play-by-play. I've been looking at that action menu for the last 3 weeks, but it's been a contiuous Huh? Too much time playing with 3D, I guess. I have insane amounts of work the rest of the week. I can't figger it out for myself right now. Describe, por favor.
--Brian
--Brian
- spasmodic_cheese
What ive done is
1) Created my character as per normal
2) Boned Him up
3) Window > Action
4) Press the First Button (New Action), type a name, press okay.
- You will see a Red Thing next to the action, this means thats what your
editing.
5) Create a walk cycle as per normal, or any bone animation.
6) Double click Mainline (main timeline) (the red thing should change to point at mainline)
7) Then click ONCE on your action and press the second button (Insert Reference)
Now if you look on your main timeline you will see a keyframe and a red shaded area with yout action name.
Try creating a new action and inserting it into the main timeline and watch them overlap!
I've tried it with only bones, it may do more!
okay hope that gets the ball rolling.
2) Boned Him up
3) Window > Action
editing.
