WAV sound doesn't play after export Animation
Lotza Mojo
Post by Lotza Mojo »
I am new to this. I have Anime Pro and I created a short 2minute animation. I imported a wav sound and then exported my animation to AVI, Windows format and the sound doesn't play. It plays fine in the preview before export. Any ideas how to fix this problem? :?
MangaManTez
Post by MangaManTez »
Is sound like the export part of your program has a problem, not what you are doing. I would talk to tec guys and if you can get you program to creat a log file when it makes the export. so you can send it to them for help.
Good luck sorry I dont have a quick fix for you :?:
I just searched 'wav doesn't export' using the 'search for all terms' option and found plenty of answers. There is a ton of useful info already posted here. :wink:
Lotza Mojo
Sound Advice
Hi,
Thanks very much I really appreciate the responses.
Mikdog
Post by Mikdog »
Hmm. I'd make sure when you export your animation, be sure its exporting from frame 1 and not frame 0 as the first frame. That sometimes stuffs things up.
Lotza Mojo
Exporting Wav Sound
Hey Mikdog! That's exactly what I discovered. A little late on the advice, but it's appreciated just the same! Thank you again!
Lotza Mojo
