Character critique
Well chucky, I was using MS Gif to convert avi to gif. That's probably why I had to cut out so many frames. I reinstalled Beneton to try with image sequence, but now it says that my 600 x 540 PNGs are too big (it says 720 x 500). I don't have the patience to import each frame (48) individually.
Any ideas?
Any ideas?
Okay, I'm pretty happy with this walk cycle. (I really didn't mean to get distracted doing that yet.) So now I can work on the shading.
http://img511.imageshack.us/my.php?image=girljf7.swf
DarthFurby
There ya go Darth! And thanks. It's nice to have this down to the little details. I'm glad you like the joints. I was more worried about the design than the rigging, so it's basically just cutout style. The line width tool is second only to the modified curvature tool.
Now I just need to regain a distinctive style. (After I finish the shading on this)
::Oh yeah, I also fixed a little 'snap' in the right leg.
Thanks Tony. Yeah all of the bones only have influence on one part each, so there is no 'stretch' at any of the joints. None of the joints actually connect in any way. This setup would've worked for image layers except that I needed to point bind the breasts. If those were a separate layer than the torso, the whole thing would have been cutout rigged.
Sorry, I just couldn't bear to give her a peg leg. I had that same 'limping' problem with the first walk cycle I did. I started this last one from scratch, starting with the hip sway. (Would you believe this is only my third, maybe fourth, walk cycle ever?)
Granted it still may not be perfect.
