making fire with Moho
Darker
Post by Darker »
:idea:
As new to Moho I have solved the way how fire can be easily simulated, and depends on your imagination how it can be used. Perhaps it isn’t quiet a great animation tip, but it helps. First draw a shape with free hand draw tool or add points tool, try it to be like a flame, name your layer and then go to style, give it a red “fill” color and yellow for its “line” color, and 5 as value for line width, then double click on the layer and modify the values of “Vectors” checking activated Noisy outlines, Noisy fills and Animated noise. Now Offset pixel = 10, Scale (pixels) = 15, and extra lines = 8, then OK. I have used it as a thrust for a Ufo’s taking off. If you wish you can change the fire shape during animation with the Timeline window in any value over 0 of course, and the layer selected, this gives extra movement. If you want to add smoke see the Moho's user manual (Tutorials/Effects/6.1 Particles) for further info. :wink:
