Moho
Darker
Moho
Post by Darker »
Hello there. I'm a newcomer and new in Moho too, I was just wondering if somebody could help me, got a problem here. When I make a character or some object move around other object the later becomes transparent and my former object can be seen. I mean, a moon in orbit around a planet, when the moon is behind the planet and should not be seen, the planet transparents itself and the moon can be seen. A character walking from side to side, when passes in front of a tree the character transparents itself an the tree can still be seen. When a character walks around a tree and into horizon, half of the character "dives" in the horizon where land ends and sky begins and only its torso is visible, (the sky and the land are two different layers). Whats is the matter, what am I doing wrong? What are the transparent layers? My characters or my landscapes? Please help. Thanks a lot....
Sounds like you just need to sort your layers so the right ones are on top. If you have a layer selected, you can see its vector lines even though it is actually under another layer.
If this is the case, I'd strongly suggest doing the help tutorials.
Darker
Post by Darker »
That's right what happens. I can see its vector lines. I understand, I will try it and see what happens. Thanks a lot.
Darker
transparent layers
Post by Darker »
Thank you synthsin75, I’ve done as you told me and it works…
Glad to help. :D
