Can you import a character from Photoshop?
Hi there. This is Seku.
I'm new around here and I got Anime Studios for some time and I am very new about it. I've seen how it works and all and understand some of it. But I want to ask. I'm a deviant artist and have been work with Photoshop for over 4 years and my question is that, is it possible to import a character that I have drawn and colored in Photoshop? Please I would like to know as soon as I can because I'm very exited. I want to take my art work into the next level.
Thanks!
Thanks!
If you log on to the efrontier site, you should be able to find a script which will allow you to export Photoshop files into AS, preserving the layer structure. If you just want to export the occasional image, use PNG with transparency -- that seems to work best.
efrontier site? do you have a link? lol sorry I'm very new around ^^;jahnocli wrote:If you log on to the efrontier site, you should be able to find a script which will allow you to export Photoshop files into AS, preserving the layer structure. If you just want to export the occasional image, use PNG with transparency -- that seems to work best.
Thanks!! ^_^jahnocli wrote:Sure:
bottom of the page
TOMMYNATOR
TOMMYNATOR
TOMMYNATOR
(hola, sí puedes usar tus imágenes de photoshop, pero si no tienes el CS, entonces el trabajo será más tedioso.
debes recortar a tu personaje en partes, por ejemplo, tronco, cabeza, brazo1, brazo2, pierna1, pierna2.
luego debes copiar la layer de la cabeza, pegarla en un archivo nuevo y exportarla como png con transparencia -o alpha-. Lo mismo con cada parte.
creo, aunque no estoy seguro, que existe un script para los photoshop más viejos que te permite exportar cada layer como un png independiente. sería más rápido.
la diferencia entre hacer esto manualmente y con el script oficial es que este último te genera inmediatamente un archivo .anme y una carpeta con todas las imágenes png que utiliza, por lo que queda sólo enhuesarlas)
Of course you can! You just have to export those images in a format that AS can understand, PNG, JPG and whatever else is listed in the TUTORIALS AND HELP FILES.TOMMYNATOR wrote:i'm really lost. so i can't use my photoshop images?
pardon my ignorance
http://www.lostmarble.com/moho/manual/i ... ayers.html
The script for photoshop was created very recently and is a Photoshop CS only script for PHOTOSHOP CS. If you only have Photoshop 7 you must export each layer from photoshop as a PNG or JPG and import to AS as an image layer.
Read the tutorials... read the help. I almost wish Mike had never created that stupid photoshop script... it causes more confusion than anything else.
p.s. I'm still waiting for the pick my nose and take a pee scripts. I hate having to do that myself.
This little script have become so so so useful for me this days. I´m working in a project in which all characters are scanned pictures in photoshop layers.heyvern wrote:I almost wish Mike had never created that stupid photoshop script... it causes more confusion than anything else.
without it pass them to AS would be a nightmare.
I don´t think it causes so many problems. it´s actually so confuse as any AS script, they are always hard to install. the difference between the photoshop script and AS scripts is that there are more beginners (I suppose it´s not the right word) which want it.
