Big timeline bug in 5.6
Yeah, just installed Moho 5.2.Rasheed wrote:No, I never did. I didn't do anything about animation for about a year, so I missed that upgrade.synthsin75 wrote:Did you ever install the 5.5 update? It may have started there.
Uh...Rasheed, I just noticed something you might want to try. It appears that setting the timeline to show all channels doesn't necessarily do it for all channels on all layer types, just the ones available for that layer.
If that's not it, then what was your previous version of AS?
DarthFurby
NetGenSuperstar
You know there are probably some channels you don't need to see all the time.
This is a problematic bug... but still... It effects bone layers only so... do you really need the layer blur channel on all the time? What about layer motion blur? Bone dynamics? Do you use this all the time?
You only need to find two options to turn off to fix the bug in most situations.
the bug SHOULD be fixed but in the meantime there is a workaround.
- Lost Marble
True, it probably doesn't need to impact you that much in most work, but it's something I'll be fixing anyway.heyvern wrote:This is a problematic bug... but still... It effects bone layers only so... do you really need the layer blur channel on all the time? What about layer motion blur? Bone dynamics? Do you use this all the time?
-Mike
