Hey guys.
I don't know if you can write a script for this or if it would have to be a software update...
anyways...
I would like the ability to change the colour of the Keyframe dots.
As an example - Lets say I select all points and keyframe them at frame 25
I would like the abiltiy to select that particular keyframe and colour it so that it stands out from the others as a major key.
This would also help as a quick way of seeing where all you major keys or poses are - with out having to scrub through the timeline.
My main reason for wanting this feature - is to quickly see important keyframes.
Thanks for reading
Coloured keyframes please
- AngryMonster
I have just been discovering scripts on another topic here -- quite useful indeed!
Speaking of the timeline, what is the use of this bright green marker which appears when you "Cmd+click" a frame (or Ctrl+click I suppose) on the time ruler (and disappears whenever you "Cmd/Ctrl +click" another frame) ?
If you CMD Click you get the green. This is the "start". CMD CTRL will give a red highlight, this is the end frame.
Hit play and it plays that section. If you just have the green start set it starts from there and plays to the end. If you have the end set (red) it plays from the beginning to that point.
these are the key commands for Mac, not sure what they are for PC.
Re: Coloured keyframes please
You should have a look to this:AngryMonster wrote:Hey guys.
anyways...
Thanks for reading
http://synfig.org/Keyframe
That are really keyframes. What Anime Studio uses as "keyframes" is what in synfig are called "waypoints" or interpolations points. And yes that's a BASIC feature. Quick jump to keyframes and move its position is a major needed feature for Anime Studio.
