Papagayo doesn't work on Mac OS X Leopard
I just installed Mac OS X Leopard and now Papagayo 1.1 doesn't work anymore.  Does anyone have any ideas how to fix this?
						Replace all Pithon words below with with the comedy team/snake name that's spelled with a 'y' - there's a default security restriction on this forum (to prevent running malicious scripts) that prevents me from posting if I use the p-y-t-h-o-n word, except in URLs and similarly safe contexts.
It appears to be a problem with the Pithon launcher configuration on Leopard rather than a problem with Papagayo, and a similar situation is showing up in a number of Mac/Pithon forums.
Option 1 (different Pithon path on Leopard):
Try doing this in a command line window:
$ export PITHONPATH=/Library/Pithon/2.5/site-packages
Then trying to run Papagayo again
(from http://the.taoofmac.com/space/blog/2007/11/11/1922 )
Option 2 (should also work on pre-Leopard Macs):
Find the Papagayo program folder, open a command line window in that folder, then try
$ pithon papagayo.py
(possibly that might be $ pithon papagayo.pyc ? or even $ pithon papagayo ? I'm not a Mac user, so I'm guessing wildly here)
(from http://www.gossamer-threads.com/lists/p ... hon/599638)
That's assuming the original Pithon source file is included with the Mac distribution of Papagayo.
Option 3:
Try option 1, then option 2 in the same commandline session
Good luck!
That's all the guessing I can do without actually getting within visual range of a Mac.
Regards, Myles.
Option 3:
Good luck!
Regards, Myles.
-- Groucho Marx
						-- Groucho Marx
				douglsmith
Papagayo console log
I also tried the above suggestions with no luck. Here's a dump of the Mac console log when Papagayo tries to start.
12/20/07 11:25:13 AM [0x0-0x49049].Papagayo[798] Exception in AE event handler function
12/20/07 11:25:13 AM [0x0-0x49049].Papagayo[798] Traceback (most recent call last):
12/20/07 11:25:13 AM [0x0-0x49049].Papagayo[798]   File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/plat-mac/argvemulator.py", line 76, in callback_wrapper
12/20/07 11:25:13 AM [0x0-0x49049].Papagayo[798]     raise 'Cannot happen: AE callback without handler', (_class, _type)
12/20/07 11:25:13 AM [0x0-0x49049].Papagayo[798] Cannot happen: AE callback without handler
12/20/07 11:25:13 AM [0x0-0x49049].Papagayo[798] : ('tvea', 'ppao')
12/20/07 11:25:13 AM [0x0-0x49049].Papagayo[798]   File "/System/Library/Frameworks/Python.framework/Versions/2.3/lib/python2.3/plat-mac/argvemulator.py", line 53, in lowlevelhandler
12/20/07 11:25:13 AM [0x0-0x49049].Papagayo[798]     AE.AEProcessAppleEvent(event)
12/20/07 11:25:13 AM [0x0-0x49049].Papagayo[798] Error: (-1, 'queue element not found during deletion')
12/20/07 11:25:14 AM [0x0-0x49049].Papagayo[798] AE error:  (-1, 'queue element not found during deletion')
12/20/07 11:25:14 AM [0x0-0x49049].Papagayo[798] in High Level Event: '0x61657674' '0x70706f61'
12/20/07 11:25:14 AM [0x0-0x49049].Papagayo[798] Traceback (most recent call last):
12/20/07 11:25:14 AM [0x0-0x49049].Papagayo[798]   File "/Applications/Papagayo/Papagayo.app/Contents/Resources/__argvemulator_papagayo.py", line 4, in ?
12/20/07 11:25:14 AM [0x0-0x49049].Papagayo[798]     execfile(os.path.join(os.path.split(__file__)[0], "papagayo.py"))
12/20/07 11:25:14 AM [0x0-0x49049].Papagayo[798]   File "/Applications/Papagayo/Papagayo.app/Contents/Resources/papagayo.py", line 23, in ?
12/20/07 11:25:14 AM [0x0-0x49049].Papagayo[798]     import wx
12/20/07 11:25:14 AM [0x0-0x49049].Papagayo[798] ImportError: No module named wx
12/20/07 11:25:14 AM com.apple.launchd[186] ([0x0-0x49049].Papagayo[798]) Exited with exit code: 1 I wrote lost marble and not to worry. They are working on a new Leopard friendly version as we speak. They still haven't changed their site though and it says the current version works with 10.4 or later which is confusing an inaccurate. It would be pretty easy to put a note up that says 10.5 compatibility is forthcoming.
If you write tech support and ask nicely they may even let you beta test it. I have a copy and rest assured it does work. There are a couple of bugs but nothing is a deal breaker so far. Sit tight and wait for the release or ask to test it. They were going to release it by the end of January but they must be ironing out a few kinks still. I would expect it to be released soon.
~Kirk
~Kirk
- Lost Marble
We do have a working version for Leopard, but it has a few bugs still. The bugs appear to be display bugs only (redraw glitches and such) - for the most part it works as expected. You can download it here if you're using MacOS X 10.5 (Leopard).
http://www.lostmarble.com/downloads/pap ... eopard.zip
-Mike
-Mike
