Graph Mode
- laniangeline
Graph Mode
Graph mode is kind of cool. I only just started to use it a little bit recently.
To get started read this:
http://www.lostmarble.com/moho/manual/i ... newnd.html
Scroll down to the Graph Mode and all will be revealed. It's kind of funky getting the hang of it but it does work pretty well.
I had no clue how to use the graph mode until I read that and followed the tutorial. Any thing I would explain would just be copied from the help file.
I started to use the graph mode just this week and I love it.
It's weird to explain it, but it is like to be God:
In graph mode you can see all the things happening at the same time. You see past, present and future.
Ok, after my religious interpretation, I have a tip and a question.
The tip is here
and the question:
when you use graph mode in a channel that has several keyframes for each keyframe (for example, in the translate layer channel you can control the movement in X, Y and Z), is there a way to move vertically the 3 levels at the same time?
thanks.
The tip is here
and the question:
thanks.
