This extremely annoying bug that appeared out of nowhere for no obvious reason has been preventing me from working.
It began with crashing while working with image layers/imports. Always in the browser window. Crashes, no dialog or anything.
Next, it got worse. Now, I worked several hours on an animated sprite for my project, and was about to export to BMP. I began, and it only rendered one layer, ignoring the visible layers. Yes, both in settings and editing view.
I tried again, then it exported only blank images equal to the frames. (650) The software crashed again. I double clicked the project file, and I get THIS.
Cannot open file. Read code error at line 426 in code file C:\Documents and Settings\Mike Clifton\My Documents\Develop\lm_tree\lib_moho\animvec3.cpp, line 67
As I'm sure you've figured out, this path does not even exist on my PC.
Nor did any keyword appear in the project file in Notepad using ctrl+f.
I can't even work now! Only a few files on my PC altogether manage to open! How can this happen, especially after managing to work just fine for a while?!
ZoneAlarm Scans show no viruses or spyware on my computer. This is just... Happening. Can ZoneAlarm interfere even when shut down? It's shut down 95% of the time I'm using the PC.
Here is the mediafire URL to the project file if you need it.
fatigue temp.anme
http://www.mediafire.com/?b9ia2ixasze
Crippling bug preventing successful use. Huge Issue.
Hi!
I think I've fixed your file!
When I opened the file I obtained the same message than you and could not open the file. But when I read "animvec3.cpp" in the error message I guess that something weird have happened to the file related to layer 3D keyframes. And voila! I found it so quick! I opened the file in a text editor and read the keyframes values looking a mean less value. I found this at line 426:
And replaced it by this:
Now the file works!
Here is the file if you want to check it:
http://www.mediafire.com/?f31l1bld51l
You should report this bug directly to e-frontier. The problem was in the anme file not in the program. But the origin for that weird value can be any interference with the operating system, other program or ... I don't know.
Good luck.
460 4 0 1.#INF 0 0.5 0
460 4 0.1 0.5 0 0.5 0
Good luck.
Talk about quick and helpful!
Thanks much! I'll see if I can get this reported. I wish I knew what I did to cause this.
EDIT: Ohhhh wait, wait, wait. I think I found the reason.
in frame 460, I had a keyframe Noisy of both values 0. That was my novice mistake really, since I'm best at still images. Only just now animating.
Thought that would stop a Noisy I set beforehand. Now that I see that keyframe has values again...
It still confuses me why it affected my OTHER files... They work now, but... Kind funky how that interferes.
If this was the reason then the bug is fairly caught! If you can reproduce it again (with a dummy file) then I think you can report properly to e-frontier because you know how to repeat it.in frame 460, I had a keyframe Noisy of both values 0
If it was the problem then AS should prevent to let the user insert a 0; 0 values for noise keyfraemes...
