updating image
Gnaws
updating image
Post by Gnaws »
This is kind of odd.
I have a PNG imported into AS. I noticed that if I change the PNG in P'shop and try to update the PNG (with the new changes) within AS it seems to ignore me -- it changes nothing. But if I update the image by pointing it to a completely different PNG (having a different name) it WILL update. But then I have to point it back to the correct file before it will update the way I initially wanted it to.
In other words, it seems I can only update an image if it has a different name.
Am I missing something?
rylleman
Post by rylleman »
No, this is an quite annoying bug...
funk-ulf
Post by funk-ulf »
I believe the fastest way to update an image (in Moho anyway) is simply to double-click its layer and then press enter. that way you dont need too mess around with the "source image" stuff...
Gnaws
Post by Gnaws »
funk-ulf wrote:...the fastest way to update an image (in Moho anyway) is simply to double-click its layer and then press enter.
This may have worked in Moho, but not in AS Pro. :(
Rai López
Post by Rai López »
Hi, how are you guys? I have wrote :arrow: THIS in a minute, I had prefered a tool script instead a menu comand one to can activate it by a button but... uf, that had required at least five! Jeje... Well, I hope it helps :)
PS: Put the file into the "C:\Program files\e frontier\Anime Studio Pro\scripts\menu\Image", you know... and then you'll be able to update your selected Image Layer with an only one click.
is ramón back??
rewelcome back :D
Rai López
Post by Rai López »
Jaja, pos GRACIAS! :D Mira, debí dedicarte esa script aunque bien pensao como que hubiera sido muy poca cosa, no? Uhm, para ti como poco la de "LipSinc with Actions" ;) o una mejor que tenía pendiente por ahí que a ver si la acabo algún día... Bueno, now I should go to the Animation:Master forum again... :roll: CIAO!
Gnaws
Post by Gnaws »
Ramón López wrote:Well, I hope it helps :)
Are you kidding? This is SWEEEEET!!
Thanks so much, Ramón!
funk-ulf
help
Post by funk-ulf »
I really need that updating images script again but the link doesn't work... If anyone have it please share...
animationkolhapur
Post by animationkolhapur »
I also need that script desperately ... can anyone upload it ?
rylleman
Post by rylleman »
Here you go;
http://www.rylanderanimation.se/temp/RL ... age_01.lua
edit, I'll post the code as well since it is quite short and I might clean out the temp-folder on my server...
ScriptName = "RL_UpdateImage"
RL_UpdateImage = {}
function RL_UpdateImage:Name()
	return "Update Image"
end
function RL_UpdateImage:Version()
	return "1.0"
end
function RL_UpdateImage:Description()
	return "Updates your Image Layer with only on click."
end
function RL_UpdateImage:Creator()
	return "Ramón López"
end
function RL_UpdateImage:UILabel()
	return("Update Image")
end
-- The guts of this script
function RL_UpdateImage:Run(moho)
--Is this an Image Layer?
        if (moho.layer:LayerType() ~= MOHO.LT_IMAGE) then
		LM.GUI.Alert(LM.GUI.ALERT_INFO, "...Ey, this is NOT and Image Layer! >:-[", nil, nil, "OK", nil, nil)
		return
        end
--If it is...
        moho:LayerAsImage(moho.layer)
	PreviousSourceImage = moho.layer:SourceImage()
	--print(PreviousSourceImage)
	moho.layer:SetSourceImage("")
	--print(moho.layer:SourceImage())
	moho.layer:SetSourceImage(PreviousSourceImage)
end
animationkolhapur
Thanks a lot .. that did work ..
funk-ulf
Post by funk-ulf »
tackartackar Image
