head turn test
KenW
head turn test
Post by KenW »
testing out bone scale + point manipulation for head turn. whaddya think?
http://kenwfilmworks.googlepages.com/headturn2.mov
Nice!
The head edge is a little strange and his left eye should be scaled also.
You should work it a little more, Keep it on!
Translate the nose to the right to give volume to the face. Be brave and translate all the parts of the face to its correct position!
You can do it also even using scale turn technique. I think DK have also a sort of translate with scale technique that allow translation if the parts of the face.
KenW
Post by KenW »
Thanks for the feedback Genette
you are absolutely right, the top of the head shape is off slightly when the head turns. will fix that as well as the right eye scaling. thanks
KenW
Revised head turn test
Post by KenW »
2nd attempt. thanks for your feedback.http://kenwfilmworks.googlepages.com/headturn3.mov
The face contour is better but the eyebrow and the eye must follow each other almost same deformation. Also I see something weird on the nose...
You must add hair.
Keep it on!!
KenW
Post by KenW »
took a litle time to study the techniques again and put together another test. thanks for your help Genette.http://kenwfilmworks.googlepages.com/headturntesting
Much better. I only would see the nose TRAVELLING to the right at the same time it is deformed. It would give VOLUME to the face...
Cheers!
KenW
Post by KenW »
Thanks again Genette for all of your help. you are a super guy and are most helpful to beginners like me.
