I'm trying importing 3D objects for the first time. I'm using 5.0.7 on my Mac, OX 10.3.7. When I import the tutorial object (the head with the long nose) it works just fine, but when I try to import a simple object from the 3D program I use (Cinema 4D) which I've exported as an OBJ file it doesn't work. What happens is a new layer is created, which turns completely white. You can see a few black lines, but they don't seem to correspond to the shape of the object, and they go way off the working outline of the file. I can't zoom out to see the object. What could be the problem here?
thanks,
Jack
Importing 3D objects
- Lost Marble
The object is probably just really huge. With the newly-imported 3D layer active, use the Scripts->3D->Auto-Scale menu command.
Depending when you downloaded Moho, you may not have the Auto-Scale script installed. If you don't see it, you can download it here:
http://www.lostmarble.com/moho/extras/scripts.shtml
Thanks, that was it. It appears now in the window. The only problem is that it is all black, as if in silhouette. I can move around it with the Orbit Workspace tool, but can only see a silhouette. In Cinema 4D I had given it a simple red material, but that doesn't seem to import. How can I get it to be not in a silhouette view?
Jack
Jack
- Lost Marble
The object should take its material from the OBJ file exported by Cinema 4D. However, not all 3D programs export things like materials to OBJ files. I don't know about Cinema 4D specifically, but it may just not include color when exporting to OBJ. Back in the 3D tab, you can change the default color for any polygons that go not have a material color applied to them - by default the polygon fill color is white.
using moho 5.07 also, and got a obj imported from wings obj export. All looks nice. But when i try to rotate the 3D object, it looks 2D and rotates alot slower than the tut 6.8???
The tut 6.8 works nicely and fast. But not if I setup my own moho file with that tutorial's obj files.
Any also having problems with only seeing 3D objects as 2D?
