it works as a button in the toolbox, when you click it (or even better assign a hotkey for it) the selected layer in the Layers box changes to the parent of the layer. Very useful if you work a lot with nested skeletons and switch layers.
Installation: Download and unzip in your >scripts>tool folder.
Then open _tool_list.txt located in the tool folder.
If there are no "Other" group at the bottom of the list add one by inserting the lines;
group Other
color	204 220 232 255Code: Select all
button	DR_select_parent_layer	JSave _tool_list.txt and refresh Moho (ctrl+F5).
Edit:Updated the installation info.
