I would like to be able to see my bitmaps current frame in outline'/wire frame. Onion skins work like this but when the current frame doesn't it makes aligning with a previous frame very hit or miss.
thanks for listening.
bitmaps and wire frames
- Squeakydave
Re: bitmaps and wire frames
I'd also like to see onionskinning for bitmaps (and generally better onionskining). As a workaround try duplicating the layer your working on then adjust the time line so you can see the pose you want and then trash it when you've finished. This, I know, is not satisfactory but it's a whole lot better than bounding boxes.Squeakydave wrote:I would like to be able to see my bitmaps current frame in outline'/wire frame. Onion skins work like this but when the current frame doesn't it makes aligning with a previous frame very hit or miss.
