fade or cross images
penne_apollo
Post by penne_apollo »
Hello,
i´m working with moho 5.3.1
how do i cross or fade in and out imported images? is it possible at all.
thanks for help!
Felix
Mikdog
Post by Mikdog »
What you can do is have the OPACITY for a layer show up on the imported image's timeline. Then, set a keyframe for 100% opacity where you want the image to start fading out, then a little later on in the timeline, set another keyframe for 0% opacity (by double-clicking on the imported image's name and changing the opacity setting to 0%). MOHO will smooth the opacity setting automatically, so that over time, it will fade out.
If you understood this, you can do the reverse for fading an image in (0% to 100% over time)
OR, MOHO has a SCRIPT dropdown menu under VISIBILITY called FADE. (Scripts, Visibility, Fade). You can chose to fade an image in or out.
jorgy
Post by jorgy »
The other thing to remember is that AS doesn't preview opacity of image layers. If you render the output or a frame, you will see the opacity you desire, but you cannot get "live feedback" of the opacity of a layer. (As far as I know, but I also put in a feature request some time ago for this).
jorgy
