Could you put here a quick Z buffer explanation?
I Only want to konw something about that becase I 'm very intrigATED...
- Lost Marble
A Z buffer is one way of drawing objects in 3D. For every pixel, you normally have red, green, and blue (RGB). With a Z buffer, you also have a Z (or depth) value.
As a 3D renderer draws an object, it first checks the Z value of every pxiel the object overlaps. If the object is closer to the viewer than the current Z value, then it is considered visible at that pixel, and the pixel is replaced with that object's RGBZ values.
If the object is further away than the current pixel's Z value, then that pixel is left alone. This allows the renderer to combine many different 3D objects so that nearer ones are displayed on top of more distant ones. The order the objects are drawn does not matter, since that is all sorted out pixel by pixel using the Z buffer.
Moho uses a Z buffer algorithm for displaying 3D layers. That's why 3D layers can move in front of and behind each other without any special layer ordering. However, there are a few cases where you might want to play around with 3D layers and ordering. In the 3D Options tab for 3D layers, you can choose to clear the Z buffer. This means the Z buffer will be cleared befor edrawing that layer, and will start accumulating once again after that.
We'll be posting a tutorial soon that shows how you can use this option to get multi-texturing type effects in Moho. It will make more sense once this tutorial is created.
Since you are creating a z-depth value for each pixel, would it be possible to output this z-buffer render, either as a true z-buffer (like a RLA file) or a grayscale image? That would open up all sorts of new compositing capabilities.
Please? You can't see it, but I'm giving you the puppy dog eyes (I can only imagine how that translates to our non-English speaking friends).
________
Chrysler australia specifications
________
- Lost Marble
