It woudl be fantastic if we could export alpha's of our work to utilize in other programmes much easier such as Vue d'esprit in my case.
Hint hint
Alpha Plane export
- Ashe Raven
Hello Ashe,
if you have the Pro version you could use the shadow trick in Tutorial 6.5 to generate the alpha plane as a black mask against white, or indeed a white mask against black. Just leave out the perspective and opacity parts.
However, I don't know if this will work with partly transparent shapes.
If instead you mean an alpha channel included in the standard image/animation, Anime Studio already does that automatically - you just have to make sure your format/codec supports alpha (e.g. PNG for images or image sequences, and the correct codec and settings for .avi or .mov files).
Regards, Myles.
Regards, Myles.
-- Groucho Marx
-- Groucho Marx
- Ashe Raven
