Breakdown always stop at 100 frame from end
Discuss Papagayo issues here
Dany
Post by Dany »
Hi everyone!
Allways i breakdown and i place my word, i cant go to hundrend frame of the end, i have to restart papa, and then i can...
Have you the same probleme?
(sry for my poor english :? )
DarkCryst
Post by DarkCryst »
Breifly... no.
Then again it might be a memory issue. How long is your audio? How many frames are there?
I had a problem in the past with a sound file that was "too short". I couldn't scroll to the last bit of audio.
I added a bit of silence to the end of my audio file and it worked fine. This doesn't sound exactly the same... but it might be worth a try.
Dany
Post by Dany »
ok,
i have offten this probleme, my audio usually are 1200 frame long.
And i just have to restart papagayo and i can go to the end..
Dany
Post by Dany »
This problem still...
luftbuefel
Change the fps and then change them back
Post by luftbuefel »
I found this problem with Papagayo also. The way I fixed it is as follows:
As soon as I found that it would not let me adjust the green sentence line to fit all the audio I changed the fps and then changed it back. This seemed to recalculate things and allowed me to adjust the green line correctly. Then I just continued doing the lip synch and it worked fine.
Dany
Post by Dany »
cool. thanks. :D
