HI LM:
WHEN I USE THE UNDO COMAND (CTRL+Z) IN THE TIMELINE,
I THINK DON'T RUN OK.
AND WHY THE CTRL+C + CTRL+V AND DELETE DON'T RUN IN THE TIMELINE TOO. THIS COMMAND ARE VERY USEFULL.
REGARDS,
CHIO.
UNDO BUG ? CTRL+C ? DELETE ?
- Lost Marble
Re: UNDO BUG ? CTRL+C ? DELETE ?
Can you be more specific? What are the exact steps you're going through that are not working as you expect?CHIO wrote:WHEN I USE THE UNDO COMAND (CTRL+Z) IN THE TIMELINE, I THINK DON'T RUN OK.
Use Alt+C to copy keyframes, Alt+V to paste them, and Alt+Backspace to delete them. You have to use the Alt-key combinations because using Ctrl+C and Ctrl+V copies and pastes control points in vector layers.CHIO wrote:AND WHY THE CTRL+C + CTRL+V AND DELETE DON'T RUN IN THE TIMELINE TOO. THIS COMMAND ARE VERY USEFULL.
SORRY, I WILL TRY BE MORE SPECIFIC WITH A EXAMPLE USINGLost Marble wrote: CTRL-Z.....Can you be more specific? What are the exact steps you're going through that are not working as you expect?
THE PROGRAM "WINK" (TUTORIAL) USED BY MYLES.
THANKS FOR YOUR ACLARATION.Lost Marble wrote: CTRL+C / CTRL+V
