Animate Paper?
Eddie
Animate Paper?
Post by Eddie »
Is it possible to animate (end view) a sheet of paper wrapping around multiple rollers, such as a sheet of paper moving along a winding path inside of a copier? Thanks, Eddie
Fazek
Post by Fazek »
Create a long, still "paperstrip" (just like if you load a very long paper into your machine) then put this into a group together with a moving rectangle, and use the rectangle to view the papersheet's missing edges and to mask the long paper. Maybe some additional works required if the paper overlaps itself somewhere.
- - - Fazek
Eddie
Post by Eddie »
Much appreciated, thanks. Eddie
bupaje
Post by bupaje »
Check out this tutorial by Lost Marble which may be helpful. Instead of water particles you would have sheets of paper.
http://www.lostmarble.com/forum/viewtopic.php?t=1956
thanks bupaje!
really!
7feet
Post by 7feet »
Don't know it you could make it as mechanical looking as needed, but perhaps a variation of LM's Object Warping Trick http://www.lostmarble.com/forum/viewtopic.php?t=1443 might work for something like this.
