simple newbie question :)
Dion35
Post by Dion35 »
Hi,
I just wanted to evaluate Moho and downloaded
the demo version. My question: Will I be able
to use the files I create now with the demo version
without watermark and grayscale
after buying Moho and unlocking the demo version?
Many thanks in advance!
Absolutely.
The demo IS the actual program. When you purchase it you just stick the SN in there and all the watermarks and limitations go away.
The demo doesn't do anything to the files. Only the application puts the watermarks in when the files are rendered. They aren't modified in any way.
I actually created several characters and started a project with the demo before I purchased. I even downloaded the demo at another location to work on stuff because I didn't have my laptop with the serial number.
Dion35
Post by Dion35 »
thank you very much, so let´s go to work :)
Dion35
Post by Dion35 »
I have another question but didn´t want to start a new topic.
On lostmarble.com it says that with the demo version exported swf-files will be displayed in grayscale. But if I export an animation as swf I just see a white screen, nothing displayed. maybe some special preferences needed or what could be the reason?
Some things don't work with the Flash export. If you use them then nothing shows up.
Too little info to be sure of your specific situation.
Dion35
Post by Dion35 »
To test it I just created 6 frames with a black rectangle (in the project settings and the swf export window any box was unchecked) but even this ended up in a white flashfile with nothing shown up. :(
Patmals
Post by Patmals »
Hi Dion,
I am also using the demo (for now)
did you create a shape out of the rectangle you created?
Maybe it is not rendering because it has been seeing a 'shape'?
Just a guess because i have rendered a black and white swf and it worked.
Pat
