Moho-Lua-Manual
teotoon
Moho-Lua-Manual
Post by teotoon »
Dear LM,
First, when will the Moho-Lua-Manual be out? Second, I am only familiar with java and flash actionscript; is there any similarities/differences between the latter and Lua?
Lost Marble
Post by Lost Marble »
I don't know when the Moho-Lua document will be out. As far as comparisons to different languages, here are some Lua links to give you a feel for the language:
http://www.lua.org/
http://lua-users.org/
7feet
Post by 7feet »
Well, I wouldn't mind something detailed, but at the moment i would just like an expansion of what the API script gives you. Specifically, just a listing of the variable related to the various API functions would help a lot. I've been able to figure out a whole lot from studying the existing scripts, but I'd like to do more and that would help. I guess the debug lib wasn't included (which I guess I can understand) but if I understand things correctly, the debug.getinfo() function would hook me up. It would be really cool if I just knew which perameters to plug in where. Just a list. I cpuld work it just fine from that.
--Brian
sherlock
Post by sherlock »
I'm with Brian. The sooner the better. It doesn't have to be anything fancy, just more detail on the parameters.
tme2000
Post by tme2000 »
Dear LM,
when will the Moho-Lua-Manual be out???
