Can we use switch layers for actions?
It doesn't seem to work now. I make some hand gestures in a switch layer and animated an action. But referencing the action in the main timeline does not work.
Switch Action
Switch Action
Sine =)
- WillBellJr
- Lost Marble
So yes, there does seem to be a bug in switch channels and actions. A switch action cannot be inserted by reference into the main timeline. However, it does seem to work if you insert the action as a copy instead. So that's the workaround until we get the issue fixed.
As far as stretching an action, you can't do that now. However, if you insert an action as a copy, not by reference, then it just becomes regular keyframes in the main timeline, and you can edit those however you wish.
- WillBellJr
- spasmodic_cheese
